How to submit Motion Solve job by using Standard Application Definition .
Field Name |
Description |
Version |
MotionSolve application Version to run the job.
Job Name |
Job Name / Default is input filename excluding extension |
Select Parallelism |
Explained below |
What is input form field “Select Parallelism Type”?
Field Name |
Description |
Number of Cores |
Select Total number of cores required for job.
Total Memory Required (in core) for Simulation (GB) |
Total amount of memory required for the job. |
Total Out of Core Memory Required (in GB) |
Total scratch disk space required for the job. |
Input file(.xml or .zip) |
Primary input file for the job where you can submit the files in the form of .xml or .zip(which should contain the .xml files for sure) |
Run Type |
Performance - If all number of cores in node is not allocated for this job, Remaining cores will not be allocated for other jobs. Throughput – If all number of cores in node is not allocated for this job, Remaining cores will be allocated for other jobs. |
Output Directory |
Directory name to copy back all job files. Default as per site specific configuration |
Step -3:Click on submit button to submit the job.
Field Name |
Description |
Default |
Queue |
Select the queue to which the job must be submitted. |
Version |
Select the version of the application to use. |
Configurable / Usually latest version |
Job Name |
Name of the job Note: Special characters and spaces are not allowed in job name.
Input file name without extension |
Select Parallelism Type |
Select the parallelism Type: 1. SERIAL: Allows the job to be run with single core/CPU. 2. SMP: Allows the job to be run with CPUs available within one node in a cluster. Uses Threads. |
SERIAL |
Number of Cores |
Select the total number of CPUs/cores to be used. |
1 |
Select the total memory required for the simulation in GB. This information is generally available in the simulation output files. Selecting a value closer to the real memory need will increase the chance of the simulation to complete successfully. Note: This is NOT the same as memory per core. |
User editable with reasonable default value based on the selected number of cores. |
Select the total out core memory required (local scratch disk space) for the simulation in GB. This information is generally available in the simulation output files. Selecting a value closer to the real out core memory need will increase the chance of the simulation to complete successfully. Note: This is NOT the same as memory per core. |
input file(.xml or .zip) |
Select the input file(.xml) or (.zip(where the .zip file should contain the .xml file) to be used with the simulation Note: Special characters and spaces are not allowed in file name. |
Run Type |
Selecting Throughput mode will cause the scheduler to find the required resources even if they are scattered across several nodes in the cluster. This may increase the possibility of your job starting sooner than in the Performance mode. Your simulations may run longer than usual. Selecting Performance mode will ensure that your job runs on an exclusive set of nodes and should expect your jobs to finish faster. On a busy cluster, this may lead to higher wait times.
Default: Performance |
Output directory |
Specify the directory where the result files will be stored after the job is complete. |
User editable reasonable default : /stage/username/jobname_timestamp |
Apart from default Additional form fields are visible here, Following are the additional form fields other than default form fields:
Field Name |
Description |
Default |
Run In Place |
Check this box if you want to run your job in the same directory where your input file is. This will prevent the expensive file copies. May impact performance of the simulation. |
User selectable reasonable default: False |
Include Files |
Select the include files to be used with the simulation. Generally, the include files are auto added. But this is only an assist feature. Please ensure all the necessary include files are added and available before submitting the job. |
Schedule After |
Select this option to schedule your job to run at specific time in future. Note that the job becomes eligible to run after the selected time. Actual start times may differ based on the resources available on the cluster. |
Kill Job After |
Specify the estimated time that your job is expected to run on the cluster. Providing a good estimate increases the chances of your job starting sooner. Note: The scheduler will kill the job if the actual wall time exceeds the estimated time specified.
Dependency type |
Specify the Dependency Type: afterok: start the current job only if the specified depend job is successful. aferany: start the current job after the specified depend job irrespective of exit status. |
Default: afterok |
Dependent on Job |
Specify the job id of a previously submitted job after which the current submission is expected to run. |
Additional Options |
Specify any valid command line options that you need to pass to the application. The options will be passed verbatim to the application. |
